Home > Help Needed / General Tech Chat > Megajolt MAP and TPS? The differences?
Ive searched the site but cant find a clear answer.
What are the differences here? Im assuming something to do with EFI?
Mike
TPS uses the throttle postion as a reference of how heavy your foot is and MAP uses the manifold pressure as a reference.
In a turbo application the TPS is useless on its own as the ecu won't take into account the extra air being blown in by the turbo. The MAP sensor will read vacuum and positve pressure so is allll goood! *wink*
So i need map then.
Nice clearcut answer.
Do i connect the MegaJolt to the Blanked off Feed on the turbo??
The one where the old Metro ECU went?
I connected mine to the pipe that used to go to the dizzy for the vacuum advance. It neds to be engine side of butterfly to show vacuum and boost.
I see. Cheers for the info.
Rob H converted my TPS Megajolt to MAP for me, cheap as well !
Ive got a spare map sensor that I also got off Rob.. Lol
