Home > Help Needed / General Tech Chat > short shift gear leaver
alandavies215
Member #: 1844
BURNTWOOD, staffordshire
hello
thought I would buy a short shift leaver to try and tighten a very sloppy gear stick but when I got it fitted it jumps out of second gear
does any one on here know how to cure this would be very greatfull cheers all
Did it jump out before you fitted the quickshit?
Edited by MikeRace on 20th May, 2008.
alandavies215
Member #: 1844
no all gears were ok just sloppy
Check the little cup thing isnt worn.
I also had a similair issue, the circlip moved and the teflon collar moved around.
Check this too.
What condition are the cotton reels in?
Anton
Member #: 764
Staffordshire
is it a cheapy 30quid stick or a proper 80quid KAD version..
If its the 1st one, then remove it, place directly in the bin and call KAD. :)
alandavies215
Member #: 1844
no it is the kad version and the cotton reals are brand new even though they move a lot ( do they do solid ones )
ive had the circlip come off too and the ball get damaged,
KAD replaced it no fuss free of charge
