| Home > Wanted > N/A 1275 short engine for rebuild | |||||||
2643 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
20th May, 2008 at 10:27:03pm
A mate killed his engine on the L2B run at the weekend, were on the hunt for a short engine (block, crank, rods) for rebuild.
![]() 142 Posts Member #: 2488 Advanced Member Edinburgh |
21st May, 2008 at 08:16:56am
I have two sitting in my folks garage, but maybe i'm a bit far to collect?
21st May, 2008 at 07:06:08pm
Yes, just a tad! LOL what sort of money are you looking for, and could you put it on a pallet for a curriour if needed?
21st May, 2008 at 09:55:10pm
You can have them for a case of beer (not stella, lol), I could put on a pallet if needed, but if I remember I don't think the crank is ok on one of them, I'm by that way on Saturday so will have a look if I remember and i'll take some pics too.
21st May, 2008 at 10:30:55pm
Top man Tony, needs to be block crank and rods, what condition are they in? Im seeing Jason tomorrow eve to do a damage assesment on the engine so will have more of an idea then.
22nd May, 2008 at 08:27:12am
To my memory, the reason the block is out was the big nut on the end of the crank was just spinning so it was cut off, think that renders the crank useless? Now I can't remember if the other engine is there or I used it?, now the rods? is that the push rods or the piston rod bits? now they are all there anyway.
23rd May, 2008 at 05:23:29pm
I managed to get pictures of it today if you pm me your address i'll send them over, it has a good crank and all the pistons are out but with it.
23rd May, 2008 at 11:25:04pm
ah?
On 21st May, 2008 shane said:
Top man Tony, needs to be block crank and rods, what condition are they in? Im seeing Jason tomorrow eve to do a damage assesment on the engine so will have more of an idea then. Cheers Shane On 19th Jan, 2010 wil_h said:
25th May, 2008 at 05:43:40pm
Not you Jason!! LOL the chap whos mini it is is called Jason too.
