Home > Help Needed / General Tech Chat > engine running at 100 degrees
Zeemax Power
Member #: 393
Oulton Park
Engine running hot. Its not the theomosat any thought it runs well ?
http://www.Zeemax.com
it will run hot on these temps 16c+..... if you are pressuring the engine *wink*
TurboDave had a block which run HOT!
LOOK AT YOUR COOLING SYSTEM ..
i run a 74 deg stat and 4 core rad and it touches over 100c no problems there, ..... a steady cruise and all is well
if you want the bananas ...... *happy*
Zeemax Power
Member #: 393
Oulton Park
makes me me a little better knowing that
Leadfoot
Member #: 781
iv heard that the oil performes best at 120c
steveobennet
Member #: 1657
wirral
thats funny because i've read that if your oil goes above 100oC then its advised that you fit an oil cooler. at 80oC is the minimium temperature required to evaporate oil contaminants. can anyone confirm this?
On 15th of Apr, 2007 at 09:08pm Vegard said:
What the fuck is that on the rear of the car? One of the most stupid things I've ever seen. Rest looks nice.
10.5 psi no idea how many banannas
have you got an oil temp sender?
remember your monitering (i presume) your coolant temperature in the head...
