Home > Help Needed / General Tech Chat > Rear Subframe Componants
Hard2DaKore
Member #: 2596
Hi there , i am fairly new too the forum =]! and i am 1st year apprentice mechanic i am keen on working on my 91 mini. problem is the rear subframe is off it and i dont know which parts i need so could anyone if they have time make a list for what i need. basically all thats attatched too the subframe - thanx Ryan
chinlesswonder
Member #: 1192
In the garage......again!!
you could buy a second hand frame thats complete, just bolt it back up with a new set of subby bolts from ebay, maybe replace the old trunnion bushes with poly ones, all depends on your budget
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
Shakespear RWYB 14.995 91.83mph
Ben H
Member #: 184
Melton Mowbray, Pie Country
Try the Haynes manual, thats what it is for. If you are trying to re-build a mini for the first time without one think again. If you have a specific quiestion then search and if there is no answer then a specific question will be in order.
http://www.twin-turbo.co.uk
