| Home > Help Needed / General Tech Chat > Metro turbo, highest psi? | |||||||
36 Posts Member #: 1611 Member Blackpool |
22nd May, 2008 at 09:42:34pm
Hi, what is the highest psi i can run a standard metro turbo at safely?
22nd May, 2008 at 09:58:12pm
10ish PSI with an intercooler and fueling set up proper. Whats wrong with the wastegete you have? On 7th Nov, 2008 Nic said:
22nd May, 2008 at 10:00:24pm
sorry forget about the waste gate, just having a blonde moment |
22nd May, 2008 at 10:03:40pm
The limit is the compression ratio, with an IC you could run 10psi, or 12 with an IC and mapped ignition.
Edited by wil_h on 22nd May, 2008. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
22nd May, 2008 at 10:05:25pm
could i use a decompression plate to do this? |
22nd May, 2008 at 10:16:10pm
yes you could, but if you have a standard head then it would be just as easy to have the chambers made larger. Ask BENROSS for a quote to do the work. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
22nd May, 2008 at 10:17:37pm
what sort of prices am i looking at for that to be done? |
22nd May, 2008 at 10:53:37pm
PM BENROSS hes the man when it comes to heads. I run a supercharger and I don't care the TB is on the wrong side.
22nd May, 2008 at 10:59:25pm
i had a go at moding my own head. athough not really suitable for high psi use(il be sticking to 8psi).
23rd May, 2008 at 10:57:48am
What sort of power would I be looking at if i ran a metro turbo with an IC and lowered compression and running at 15psi?
23rd May, 2008 at 11:48:04am
I think Alex B's Frog is in that spec and is about the 140 banana level. Bear in mind you will need straight cut drop gears and could be on the limit for your standard gear set at that boost level. It starts to get expensive at that point! On 7th Nov, 2008 Nic said:
23rd May, 2008 at 12:00:43pm
the limiting factor is the clutch first this will start to slip around 12 psi.....ish and.. then the drop gears and then the diff are the next weak links in that order
23rd May, 2008 at 12:19:01pm
I think i will probably invest in s/c gears anyway and at the same time fit a new diff. What sort of clutch would be best suited? |
23rd May, 2008 at 12:52:34pm
For that setup you will need a pre verto with a grey spring and ap race clutch plate or similar.
haha, what would i need to change to be able to run it at a higher psi?
