Home > Help Needed / General Tech Chat > sorry short shift again
alandavies215
Member #: 1844
BURNTWOOD, staffordshire
hello
sorry to ask again but having trouble still sanded the little ball at the end like I was told, and took about 4 mm of the end like I was told but still strugling to get 2nd and reverse
any sugestions please
Turbo Tel
Member #: 588
Delaware, USA
When you say struggling to get reverse is it that you cant get over there with collar lifted or you cant pull it down to get it in gear?
Terry
alandavies215
Member #: 1844
hello mate
what it is it will pull back into 2nd and it seem to only got half in u know the point where it is grinding on the gears it is the same in reverse u lift the cooler it goes in but not all the way but 4th seem ok goes in fine
any sugestions mate
Turbo Tel
Member #: 588
Delaware, USA
Sounds like you are running out of throw, .. Normally I would say the engine is "too far away" as when you pull the stick back the rod goes forward.... strange when the whole point of the quickshift is to amplify the throw.
Maybe check your rubber mountings for the gear stick box? if they are loose/sloppy the whole box would shift back when you tug on the stick, pulling the assembly away from the engine..
alandavies215
Member #: 1844
hello
just read your other link and you menchend about modefying yours what was it u had to do
mines a bit weard as the normal stick was great just a bit sloppy
It isnt something daft like the rod being upside down, i once did this.
Turbo Tel
Member #: 588
Delaware, USA
On 23rd May, 2008 alandavies215 said:
hello
I had to reduce the size of the ball and make the pin lift all the way but no problems like yours, Its actually working well.
Maybe try levering the gearchange assembly forward a bit and if it goes into gear better then something is preventing the rod from going forward enough. However its strange, if I remember correctly there was plenty of spare movement forwards and backwards.
