Home > Help Needed / General Tech Chat > Boost gauge only showing vacuum
JordieNE
Member #: 1591
Prudhoe, Newcastle
Hello all.
Ive got a problem with my boost gauge. It will only show vacuum which is around 20-30 on the gauge at idle. When i rev it up, it goes to zero. I cant drive the car as its not MOT'd and taxed for the road.
I have taken both my dump valve and gauge from the inlet manifold, where the servo bolt would usually go i believe.
Ive taken the bolt out and blown through it both ways, so i dont think theres a one way valve in the bolt.
Any ideas?
Also, the bleed valve. which way is which to increase/decrease?
thanks
Edited by JordieNE on 24th May, 2008.
It won't make boost sat revving it on the drive. It will only make boost under load, e.g. actually driving.
JordieNE
Member #: 1591
Prudhoe, Newcastle
i'll have to find some private road to test it, cos currently i dont know what its boosting at. I drove it the other week around the corner, but was too busy watching other things then the boost gauge.
