Home > Help Needed / General Tech Chat > Single bolt front subframe differences??
Richspec
Member #: 300
Cumbria
Does anyone know what differences there are between diff age front subbys??
IIRC the first spi frames had the engine mounted forward a bit (1/2 an inch???) to make room for the injection setup.
When the multipoints came out did the mounting point move back to make room for the front rad? or is it just the same?
Rich
Here for the craic..
Supercharged Arden powered
Think its just the same, they didnt have a dizzy so that makes some extra space.
killer_chiller
Member #: 325
SPI and MPI frames are the same manual- engine forward slightly
Pre spi and mpi manual - engine in original position
Pre spi and mpi manual auto - has a wider gap between the engine mounts, you will need spacers to fit a manual and need to drill a new mounting hole on the passenger side of the frame at the front.
There is also the older twin bolt subframe - which i use myself, this one is quite good as it bolts strait to the shell, but i do need spacers as with the auto frame above for a manual gearbox.
Hope this helps
BA_Lordflash
Member #: 26
Cannock
the MIP and SPI front subframes are the same. They mount the engine about 10mm further forward
Richspec
Member #: 300
Cumbria
Thanks, was hoping the two injection ones might have been different, never mind :(
Rich
