| Home > Technical Chat > Smoking with 15w40, no smoking with 10w40 ! | |||||||
520 Posts Member #: 2093 Post Whore Grenoble, France |
26th May, 2008 at 12:08:53pm
std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
![]() 6753 Posts Member #: 828 Post Whore uranus |
26th May, 2008 at 06:15:35pm
could the 10w40 be running out of the head faster cos its thinner ,so it doesnt sit around the guide so much ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
26th May, 2008 at 08:18:48pm
this seems silly to me, no seals fitted what guides do you have in??? what make
![]() 4641 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
26th May, 2008 at 08:48:47pm
Why have you installed the guides 3mm higher ? |
26th May, 2008 at 09:11:49pm
Guides are new std for a std 998 head (std valves and the rest). They were "bored" to get 0.05mm play, as they collapse during installation (done by a workshop).
27th May, 2008 at 10:46:26am
the engine is seeing vacuum on idle and with no stem seals on the intake valves the vacuum will be drawing the oil thro the guides i suspect, i never fitted exhasust stem seals on turbo head with the fatter valves but you defo should have them on the intakes. no longer a series, but still 1.3 turbo.
29th May, 2008 at 03:09:48pm
Finally physical laws came back :).
