Home > Help Needed / General Tech Chat > Rough idle
matt101
Member #: 1457
Hi all. Running a 1293 turbo at present, engine is a fairly new build, have covered around 1200miles. I have noticted recently that on idle its runs rough, almost sounds like it is running on 3 cylinders, i have checked all plugs/ leads, all ok. When driving and reving the engine its fine. Im using an avonbar phase 2 cam, just wondering whether this would cause it and now the engine has been run- in it has all settled down? I hav also noticed a small air sound coming from around the rear right of the engine (rad side), hav checked all the pipes for leaks and cannot find any, any ideas what this could be? could it have an effect on the idle? Cheers Matt
do a compression check first
