| Home > Help Needed / General Tech Chat > Alternator wiring | |||||||
27th May, 2008 at 12:42:00pm
Hello, i have a small nippon alternator with 3 pins like so http://www.westfield-world.com/img/Denso1.gif i have wired one of the two brown wires from my starter solenoid (on the inner wing) to the post and the other to no 2, the brown and yellow wire is connected to no 1. With the ignition off the alternator starts to get hot all by itself, any ideas? Cheers |
27th May, 2008 at 12:48:41pm
Just realised, i should prob connect both fat brown wires from my solenoid to no 3 and then run a seperate switched live to no 2? |
27th May, 2008 at 12:50:50pm
The 2 thick brown wires should both go to the threaded fitting. The wire from the charge light (brw/yel I think) needs to go to number 1. A seperate SWITCHED wire needs to go to number 2.
27th May, 2008 at 12:51:53pm
Lol. I took a kitkat break mid typing. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
27th May, 2008 at 03:24:25pm
Lol, thought as much cheers |
27th May, 2008 at 04:15:23pm
There must be something different between these alternators then as mini alternators always had the battery and switched feed from the same source, confusing huh. |
