Home > Help Needed / General Tech Chat > front coilovers
is there anypoint in using just front coilovers with uprated cones and shocks on the rear? i know a few cars do this (more modern) but dont have rear rubber cones.
#1 is it worth doing or a waste of time?
#2 would it improve handaling at all?
#3 how low can you get cars on coilovers to go
#4 how difficult is it to change spring rates//get custom springs
please help :)
alandavies215
Member #: 1844
BURNTWOOD, staffordshire
hello
I have coil overs all round and had to wind the ride height half up and still catches the rear arches and only got 12 wheels they do go low, but easy to ajust
I'm going for coilovers all roung on my clubby so I think it's worth it.
I believe it will if you use the correct spring rates and set it up correctly.
Depends how you mount them, but in theory you could have the car running on the bump stops all the time, not sure you'd want it that low mind.
Easy, phone / visit Merlin.
i only really wanted to get front coilovers this is why im asking is it a waste of time? and cheers for the input
