| Home > Show Us Yours! > How do I put a turbo on this? | |||||||
928 Posts Member #: 65 Post Whore South Yorkshire |
22nd Aug, 2003 at 05:14:39pm
Edited by iain on 23rd Aug, 2003. |
![]() 323 Posts Member #: 41 Senior Member |
22nd Aug, 2003 at 05:48:57pm
you will need to fabricate a plenum chamber which covers your filters over the carbs, as far as the exhaust is concerned im sure u can use the turbo manifold as the zaust ports are on the back same as a normal head A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white| |
1st Sep, 2003 at 12:23:32pm
Cheers for fixing the pic Edited by Neil8p on 1st Sep, 2003. |
244 Posts Member #: 34 Senior Member |
7th Sep, 2003 at 08:33:05pm
You might have to change the carbs as well.
10th Sep, 2003 at 05:30:37pm
Why do i get the feeling Neil is taking the pizz??? On 17th Nov, 2014 Tom Fenton said:
15th Sep, 2003 at 12:38:53pm
It was sort of a tongue in cheek question, but if it's feasible to do they why not. |
