| Home > Help Needed / General Tech Chat > Engine Crank Damper/Trigger Wheel | |||||||
![]() 143 Posts Member #: 2764 Advanced Member Halesowen |
3rd Jun, 2008 at 12:46:18pm
Hi all,
1994 Mini Mayfair, 1330, Mspd Ph2 cam, Benross turbo head, 9:1, GT1752, TT Intercooler, MegaJolt, BMW M3 leather seats. |
3rd Jun, 2008 at 01:19:18pm
think MED makes one. I have machined the trigger wheel into the outer ring on the S damper set up. Works fine. |
3rd Jun, 2008 at 01:30:42pm
On 3rd Jun, 2008 miniminor63 said:
think MED makes one. I have machined the trigger wheel into the outer ring on the S damper set up. Works fine. Indeed, they do. http://www.med-engineering.co.uk/product_d...02&vlang_id=545 In the 13's at last!.. Just |
3rd Jun, 2008 at 04:15:59pm
Is that MED one actually a damper pulley though ??? Or just a lightweight pulley. It isn't clear from their photo or description.
3rd Jun, 2008 at 04:24:16pm
The rubber on the A+ ones can look quite bad, but if you take a sharp stanley knife and run it around the rubber cutting off the very top layer, in the majority of cases you can see that the cracks are only on the surface and superficial.
3rd Jun, 2008 at 05:07:15pm
the MED one is the pulley to which the S damper is bolted. so it has no damper on on the pics! |
3rd Jun, 2008 at 05:21:59pm
the MED one is the pulley to which the S damper is bolted. so it has no damper on on the pics! ...which would explain why the trigger teeth are on the back !!! So why don't they say so in the description or photo :) Schrödinger's cat - so which one am I ??? |
3rd Jun, 2008 at 05:26:54pm
I also machined an S damper,
3rd Jun, 2008 at 05:52:47pm
or the first page to be more precise |
3rd Jun, 2008 at 05:54:24pm
