Home > For Sale > Bits and pieces for sale
Badger
Member #: 1488
Since I've got a new project incoming, I need to get rid of the bits I acquired for my mini, so in no particular order, here's what I have for sale:
MG Metro 1275 A+ engine, 60k miles on the clock, unleaded head. Never run it myself but should run with just a oil change. No intakes, starter not mounted but will come with it. No dizzy. £150, got an engine crane here to help loading but no tackle.
Front subframe with all on it- driveshafts, hubs, discs etc. From a 1989 City E. Bit shabby, could use a clean up but good to go. £75
Front and rear subframes (bare)- rear is partially stripped of paint. Both in good condition. £20 each.
Indicator stalks, good condition. £30
Doors- both need some work. One (drivers side) has been stripped and will need the filler sanding back and a coat of paint. The other (passenger side) needs some work (minor- no major rust can be seen). £50 each, £90 both
Glass- free to collector, though it is not in good condition. Has metal flecks from grinding on them, but that may buff out.
Metro vented 4 pots- Disassembled for cleaning, just needs cleaning and reassembly (needs pressing). Calipers only. £30
4 steel wheels, tyres are pretty much brand new. 12", big tyres fitted. £30
Heater Unit, worked fine when removed. £20
A series pistons and con rods for a 1293 overbore, dished. Don't know much about them, they need rings but seem to be in good condition though used (not by me). £30
Instrument pod £20
I think these are reasonable prices, but if you disagree please message me- I've been out of the loop for a while. Any enquiries please message me.
Edited by Badger on 5th Jun, 2008.
There is no sense crying over every mistake- you just keep on trying til you run out of cake.
Leonard
Member #: 806
Cirencester, Gloucestershire
if you cant sell the subframe setup i'll buy the potjoints and driveshafts
longy
Member #: 2727
Bicester
Hi im interested in the pistons if you still have them for sale
1972 998 TURBO SLEEPER
boldy
Member #: 2464
Weston-Super-Mare
Interested in the front subby. What isze wheels were you running on it before?
