Home > Help Needed / General Tech Chat > Pressing Bearings into the SC Lightweight hubs.
Anton
Member #: 764
Staffordshire
I have a pair of johnk's alloy billet rear hubs.
I usually just tap the bearings and wheel studs in with a hammer until they are fully home..
Is this ok to do with the alloy billet type? or should i be looking at an alternative method?
Anton
Jason G
Member #: 1459
En-suite user
Braintree, Essex
On a drum, I normally use a socket & hammer. Lightly tap, don't go mad on it.
Edited by Jason G on 4th Jun, 2008.
On 19th Jan, 2010 wil_h said:
grind down an old race and use it to press the new bearing in, well thats what i do
AllanMcD
Member #: 414
Dalbeattie Scotland
If you warm the (alloy) hubs with a heat gun the bearings will go in a lot easier.
Allan
http://www.rabdunn.co.uk/
Allan
or drop them in some very hot water, for a few secs,
carl
Ben H
Member #: 184
Melton Mowbray, Pie Country
When I did the ally ones on my Lotus I put them in the oven for 10 minutes.
http://www.twin-turbo.co.uk
AllanMcD
Member #: 414
Dalbeattie Scotland
What about the microwave *wink*
Allan
only joking
You want to press bearings into your microwave? Are you crazy man?!
super fast cooking... make that plate spin faster.
Sir Yun
Member #: 1592
Smart Guy!
Oven at 100-120 celcius (to be shure not to cause trouble with the heat treatment)
do that with gearboxes as well with the bearings in the freezer
Edited by Sir Yun on 5th Jun, 2008.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Aunt Bessy do bearings???
andywaller
Member #: 1826
Maldon Essex
i think you will find that the bearings will need very little froce to push them in.
when i went to do mine they went in very easily, so i emailed john to find out.
"Hi Andy - bearing fit loctite is perfect for the job - the tolerance is designed to be a light press fit, not a heavy fit like cast iron as this would "tear" the alloy - you're right some bearings are better fits than others but a smear of bearing fit will be perfect.
John"
Anton
Member #: 764
Staffordshire
cool... I will heat the hubs slighty and cool the bearings then and a dab of loctite to be sure.. thanks guys!
Why doesn't John K reply here...
he dosn't need to really, its a simple enough job, just warm the hubs up[ boiling water will do the job] use a bit of locktight as John suggests , simple really,
carl
johnK
Member #: 690
Norfolk
As I wasn't asked direct - thought I'd keep out of it'lol!
JK
If Carling made Mini engines
Blimey, have these been in my garage that long!
Fitted then tonight, all above tips perfect.
Only thing is that I can't get the cap back on to seal the front. anyone else manage it?
Go in and out of the old steel ones nicely.
Anton
Member #: 764
Staffordshire
I left mine out for that reason
think of the weight saving *wink*
Edited by apbellamy on 1st Feb, 2011.
Humm. Well for the use the car gets I know it won't be a problem. But I'd rather keep the bearing dry. And it looks a bit bobbins with it not fitted.
Didn't somebody recently get some plastic trailer hub nut covers that where a snug fit? Just need a small amount turning of them. Might work for you.
After a bit of measureing the SC hubs have an ID of 51.2 mm, the caps are 52mm OD.
I have ordered two 51mm caps from a trailer place.
Ben H
Member #: 184
you could have got 4......
I don't recall you having a set. anyway, they might not fit yet.
Ben H
Member #: 184
Yep, I got 2 sets and gave one set to you. Keep up...
