Home > Help Needed / General Tech Chat > 1275 - 998 diff differences
boldy
Member #: 2464
Weston-Super-Mare
Is there any big difference between the diffs themselves? obviously the final drives will be different but the main diff? will that be any different?
Nothing different about the diff itself.
The crown wheel and pinions can differ though as you say.
turbo hogster
Member #: 178
stowmaket suffolk
the only diffrernce is between a series and a+
A+ have tagged planet thrust shims
weres a seies do not and were out the diff casing
just use the a+ one if thats you thing
That diff pin block disappeared in the 80ies sometime as well. Bad idea!
