| Home > Help Needed / General Tech Chat > dump valve & boost gauge | |||||||
271 Posts Member #: 1844 Senior Member BURNTWOOD, staffordshire |
7th Jun, 2008 at 12:47:52pm
hello
7th Jun, 2008 at 12:55:42pm
the dump valve will oly make a noise when there is boost pressure, the small pipe from it conects to the inlet manifold so when the throttle shuts it is sucked open and will vent any boost pressure.
7th Jun, 2008 at 01:13:40pm
And you won't get any boost when just revving, you need to drive the car.
7th Jun, 2008 at 01:46:20pm
thanks lads put my mind at rest |
7th Jun, 2008 at 08:14:08pm
is it not possible to rev an engine into boost then?, only under load?. I have a similar symptom with mine, tried to rev it up to hear the blow off valve but cant hear much. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
7th Jun, 2008 at 08:32:56pm
about the erratic boost gauge how can I stop this or is this how it is thought I might be able to get a smooth reading |
7th Jun, 2008 at 08:48:22pm
On 7th Jun, 2008 chinlesswonder said:
is it not possible to rev an engine into boost then?, only under load?. I have a similar symptom with mine, tried to rev it up to hear the blow off valve but cant hear much. If you really rev the tits off it you might get some boost, but generally you need to put the engine under load. When under boost the gauge should be steady, but at tickover and over run it will move around. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
7th Jun, 2008 at 11:37:53pm
give us a ring or something tomorrow if you want dude, can call round on the way back from curborough. On 20th Oct, 2015 Tom Fenton said:
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
8th Jun, 2008 at 04:20:36pm
i put a restrictor in the vac pipe to the boost gauge and it made it nice and steady. If its pissing you off it might be worth considering. |
8th Jun, 2008 at 05:05:25pm
what do u mean a restricter |
9th Jun, 2008 at 09:42:53am
been trying to find a link on the web, but there are no pics. My gauge was supplied with a t piece and one of the legs had a little brass insert in it to restrict the flow of air. This smoothed the gauge out.
9th Jun, 2008 at 10:07:26am
cheers mate will try that |
249 Posts Member #: 513 Senior Member Sheffield |
10th Jun, 2008 at 07:48:39pm
What diameter was that Ric? Noticed my gauge was a bit flappy on idle. |
10th Jun, 2008 at 10:43:31pm
can't remember to be honest, was ages since i fitted it. I think the OD was about 3-4mm and the brass insert took it down to about 1mm. I can take it off at the weekend and take a pic if that helps. :) |
10th Jun, 2008 at 10:49:50pm
Ah cheers don't worry though mate now I've got a rough idea I'll have an experiment and see what works. |
![]() 189 Posts Member #: 1774 Advanced Member Sydney AUS |
16th Jun, 2008 at 04:54:54am
Mine is erratic on idle. Off boost just shows vacuum when throttle off (normal) and is smooth when cruising and then smooth on boost. Bounces only a little, and doesnt bother me on idle... sounds normal to me too.
1132cc Turbo ~120 bananas ATW - Fun Fun Fun
