Home > Help Needed / General Tech Chat > Clevis pin majic dust
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Does anyone have any? Or any tricks to get them extracted without too much grief? The split pins are easy and the clutch one is out, just the brake clevis to go and it is not moving an inch. It was only taken out 5 years ago but I think some brake fluid got down there and rusted it on. What do I do?
Thanks.
On 7th Nov, 2008 Nic said:
naeJ
m
Jay#2
Member #: 648
It's OK peoples, I somehow managed to purswade it out by poking a screwdriver through the hole in the bulkhead when I lifted up the mastercylinder. Now to put it all back again! Yay!
naeJ
m
El Potter
Member #: 2169
Malta (Ex. Scotland)
Guaranteed hours of fun*happy*
Warning:Stig in Training
Putting it back in is always much more difficult than taking it out! (ooo urr)!
Jay#2
Member #: 648
Last time I stuck the clevis on a long screwdriver with blu tac and slipped it in. Thats the plan this time but I have got distracted by shiny sunnyness.
naeJ
m
Like Hell it is.
I've spent all day putting in the brakes/clutch pedal box, master cylinders and making new pipes.
Worst job was the clevis pins.
Trick is to hold the pin with two fingers, get it in place, remove a finger so the you can wiggle it in place with the other, whilst wobbling the pedal with the other hand.
Then you have the fun with the split pin. I turned the clevis pins so that the hole was horizontal and then put the split pin in with needle nose pliers.
Hours of grunting, sweating and blaspheming.
clevis pin easy if you know how, ,and i must know because its a pissball ,lol
They should put this description in the haynes manual! *happy*
thr trick is to hold the p[in in the jaws of a small pair of snipe nose mole grips, hold it around the shoulder so the pin is at 90 dgs to the grips, it makes locating the pin piss easy,no need to struggle trying to get fat fingered hands in the tiny space,
carl
With the exception of the ones on the CV joint's I've replaced all my split pins with R clips, it makes life a lot quicker and easier and if you want to be really flash you can buy coloured R clips for a model shop.
danboy
Member #: 1381
Got a load of "R" clip' PM if you want one.
Dave
Turbo Shed
Member #: 30
Epsom, Surrey
easy job, first fit a rover cooper servo and the pin will take about 5seconds to fit, and the brakes will feal better!
I've just took the servo off *Rofl!*
littlejem59
Member #: 2544
Biddulph, Stoke on Trent
O.K. Clevis pin replacement-
cut a strip of steel say 1" wide to a length to allow the end to comfortably reach the head of the clevis pin without the need to shove your hand in amongst all the gubbins. Cut two slots in the end about 3/4 inch long and as wide apart as the clevis pin diameter. bend the centre strip (formed by the slots) back a liitle Slide the pin between the two outer prongs, bend the center strip down over the head of the clevis pin and hey presto you have a clevis pin holder/insertion tool. you then set the pin so that the split pin hole is facing you then slide in the clevis pin, pull out the tool press the pin all the way home and fit the 'R' clip with a pair of long nosed pliers. Tool takes 1/2 hour to make, the clevis pin replacement a few miniutes. Hope that makes sense, pictures are better than words i'll try and post a sketch. :)
It's not the age that makes me creak it's the mileage
