| Home > Help Needed / General Tech Chat > Help to all you turning specialists!!!!! | |||||||
![]() 730 Posts Member #: 1791 Post Whore Cranleigh, surrey |
9th Jun, 2008 at 08:15:34am
I need a lathe expert to rustle me up (costs will be covered naturally) some rack stops. The ones from KAD are pants and slide up and down my steering rack. So i need some slight undersiezed ali ones then i can heat them up and slide them over wait for them to cool and hey presto!!!!
"Cars are a lifetime of pain" |
9th Jun, 2008 at 08:33:41am
Not sure what they look like but sound like some kind of collar? Could you drill the stops you have and put some grub screw in them to stop them moving? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
9th Jun, 2008 at 10:00:28am
i could but kad in there weird ways have put a split in them so you are apparently able to squeeze them over the arm then zip tie them in? apart from the zip ties/cable ties hit on the rack housing anyway, so there pretty rubbish from the word go? if there ally and an interference fit then i can also grub screw them if i need to? i am willing to pay. i just don't have a lathe, i can supply drawings etc.... "Cars are a lifetime of pain" |
9th Jun, 2008 at 10:20:23am
Weird.
Edited by wil_h on 9th Jun, 2008. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
9th Jun, 2008 at 10:26:50am
easy take the control arms of, there are 2 types of rack apparently, when i first ordered the stops, i got the early type (apparently more common) and they didn't fit at all cause there to big, thus the stop was thinner, so you could bend it over the arm. if you make the bush thicker then its almost impossible to get them over the arm without miss shapping them, so i took the arm of to fit mine. Once on though they were still a little loose, and even when they were cable tied. So if i had ali ones, then i won't worry about them sliding down my shaft (as the actress said to the bishop?) i'm sure to an experienced machine operator its a 10 minute job? "Cars are a lifetime of pain" |
