| Home > Help Needed / General Tech Chat > PLEASE help .... wont start! | |||||||
107 Posts Member #: 2556 Advanced Member Southport, Merseyside |
10th Jun, 2008 at 01:35:03am
Hi.IT WONT START!! i have a fully rebuilt engine with....
567 Posts Member #: 102 Post Whore Pennsylvania USA |
10th Jun, 2008 at 01:50:19am
Have you had the distributor drive out? |
10th Jun, 2008 at 02:43:31am
this happens ...and it pisses many peeps off Edited by BENROSS on 10th Jun, 2008.
![]() 1913 Posts Member #: 1392 Pointless Post Whore Liverpool, North west |
10th Jun, 2008 at 07:40:11am
Not 1-4-3-2 Steve,
Edited by Jordan on 10th Jun, 2008. Back once again like a renegade master |
10th Jun, 2008 at 08:02:54am
It can only be fuel or ignition so you need to rule one out. If you have a decent spark (and check the timing as above) then you have to assume fuel.
http://www.twin-turbo.co.uk
10th Jun, 2008 at 09:17:38pm
If i use easy start it fires but on the odd occasion but will not run. the firing order is correct. How much of what oil goes in the dashpot. the oil i put in was very thick. am really stuck. thanks for the advice!! appreciate it. |
10th Jun, 2008 at 09:22:31pm
an not 100% sure what the dizzy drive is. I have had the dizzy out tho. sorry im not exactly a mechanic. so u will have to excuse some of my terms. lol. .thanks |
461 Posts Member #: 91 Senior Member Live @ Worksop, Work @ Rotherham |
10th Jun, 2008 at 09:37:17pm
remember there are 2 TDC, make sure you have TDC with both valves closed as the piston rises |
10th Jun, 2008 at 09:53:07pm
yes your right jordan
10th Jun, 2008 at 10:15:50pm
could the needle in the float be stuck , not allowing fuel into the bowl?. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
249 Posts Member #: 513 Senior Member Sheffield |
10th Jun, 2008 at 10:35:19pm
You need to pull the dizzy and then screw a bolt into the drive that is retained in the block. Pull it out and re-engage it so the slot is angled toward 2 o'clock with the smaller section on the top.
Edited by andygardner on 10th Jun, 2008. |
11th Jun, 2008 at 02:12:27am
Thanks for the advice. will try in the morning and let you know how i got on!! |
12th Jun, 2008 at 12:48:25am
Thanks to eveyone for the help. I forgot to add, the engine was built last year and has been sat for a while so we towed it round the block in second gear and she fired up straight away I was out slightly with the timing but was corrected by a friend. Thanks again for the help!! Graham |
12th Jun, 2008 at 07:51:25am
Where about are you in southport? Back once again like a renegade master |
12th Jun, 2008 at 08:00:23pm
I live in town literally 2 mins walk from the centre. |
