Home > Help Needed / General Tech Chat > Boost.........
Giancooper
Member #: 2402
Hi my motor is an supercharger, 8.2 CR,
but have crank (whit a centre main strap) and rods of n/a just polish....
Can I run whit 12 psi whitout problem?*happy*
The crank and rods are not the limiting factor here.
What SC have you got? suck through or blow through?
Giancooper
Member #: 2402
Blow through whit an intercooler...
Well then, depending on the efficiency of your SC at 12 psi I don't see whay not. If it's a M45 of a MINI I doubt you'll see any gains over 10psi though.
Giancooper
Member #: 2402
Yas is the m45 the supercharger....
thanks.
i would be interested to see the blow through setup and intercooler with m45
Giancooper
Member #: 2402
mo problem....
that looks pretty cool! shame it won't fit under a standard nose.
akirch
Member #: 399
Austria
very nice!!!
do you have to modify the bonnet?
Edited by akirch on 11th Jun, 2008.
http://www.minifreunde.at
Giancooper
Member #: 2402
No, the bonnet is original
