| Home > Help Needed / General Tech Chat > Aluminium Filler Rod | |||||||
11th Jun, 2008 at 05:30:23pm
I need to get some aluminium filler rod to weld my intercooler tanks.
Edited by Paul S on 11th Jun, 2008. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
11th Jun, 2008 at 06:55:28pm
I use 4043A
11th Jun, 2008 at 07:18:39pm
Thanks Rod.
11th Jun, 2008 at 07:40:26pm
On 11th Jun, 2008 Paul S said:
Thanks Rod. I have found some info and 4043 looks like a good starting point. You should choose the filler rod based on the base metal, but when did you last buy a sheet of ally and actually know what grade it was! Now need to sort out a tungsten. Zirconia maybe? the 1050 will be pure, , anodises ok, as there is no silicone content, BUT, as its a very soft aluminium it can grack on contraction if used on big stuff, i know evry grade of aluminium i buy and use,lol. carl |
11th Jun, 2008 at 07:52:11pm
Yes,
11th Jun, 2008 at 08:02:14pm
Thanks again.
11th Jun, 2008 at 08:19:03pm
My only advice there would be - practice first (kind of obvious) but on something similar (ie similar sized casting/plate).
11th Jun, 2008 at 08:41:01pm
I'm going to practice on some scrap, then build up the end tanks before welding to the core.
11th Jun, 2008 at 08:52:04pm
Whoaa...
11th Jun, 2008 at 08:56:49pm
i too hav not bothered with a foot pedal yet even with thin ally,
11th Jun, 2008 at 09:09:24pm
Yes,
Edited by Rod S on 11th Jun, 2008. Schrödinger's cat - so which one am I ??? |
11th Jun, 2008 at 09:47:45pm
My TIG welder is the pulse type. So you can set the base and pulse current, pulse width and frequency.
11th Jun, 2008 at 11:50:50pm
Type "tig remote hand control" into google and you'll find some options on common sets.
