Home > Help Needed / General Tech Chat > Hunting on Idle
b12
Member #: 247
Kent/Surrey Borders
another wierd one after my RR session
Cannot get it to idle less than 1500 RPM
And it also hunts continoulsy
They said the manifold gasket was leaking l but I have had a good look and it does not seem to be leaking anywhere ??
Please guys
I have sunstroke as I spent the day fitting my Toad alarm
S
TurboLessTosser
pete
Member #: 275
bonie scotland
manifold or carb casket got a leak spray wd40 on casket area when engine running, listen for engine noise changing, if you have co meter you will see mixture changing all the time
b12
Member #: 247
Kent/Surrey Borders
i do get smoke from the heat shield under the carb ...
I think the carb must need a rebuild dont you ?
the engine speed definatly goes up and down as well
Edited by b12 on 31st Jul, 2004.
TurboLessTosser
