Home > General Chat > Matalic paint tips.
MarkGTT
Member #: 1194
Shropshire.
Hi all, the car has been dry built for a few years - im now pulling my finger out and getting it all sorted.
i painted it a while back to help prevent rust and its stood up well, but the inside needs doing so im thinking of changing the colour while i do that.
whats the rules for painting a matalic? can it be wet sanded, do i need to adapt my painting stye from a solid colour etc?
cheers, Mark.
El Potter
Member #: 2169
Malta (Ex. Scotland)
As far as I know it can be wet sanded, but go easy on it.
And you shouldnt have to change your style at all.Though if you keep too slow a pace you might end up with too many flakes in the paint.Same goes for too fast a pace.
Warning:Stig in Training
martpaul
Member #: 668
newton aycliffe (near durham)
You dont sand the paint! You can sand the clear coat though!
turboestate
Member #: 362
durham area
style stays the same, nice light coats or you may end up with dark patches then loads of clear coat nice wet sand i use 2000 grit, then a nice polish with g3 and some wax, might be worth checking the size of nozlle in your gun generaly use 1.2 for metalix and a 1.4 for solid colours. have used both sizes with good succes though.
love that straight cut scream!!!
______
/___|_____
_ (@)___(@)
MarkGTT
Member #: 1194
Shropshire.
Ok cheers guys.
So basically the same as a solid but dont sand it until the clear is down.
El Potter
Member #: 2169
DOH.
Martpaul thanks for that mate.
Forgot to Engage Brain before replying
turbogt
Member #: 2314
cumbria
All the top bodyshops have stopped wet sanding as far as i know. This is because the water gets into areas that you dont see and when you paint it traps it in and causes future problems. I was told this by a very good bdyworkman. Maybe something to bare in mind.
