Home > Wanted > Off cut of phosphor bronze
I'm after an off cut off phosphor bronze about 1 1/2" diameter by about 1 1/2" long to make a new bush to go in the tail stock of my lathe, for some reason the previous owner thought it would be a good idea to make a steel one.
Edited by Rob H on 14th Jun, 2008.
Anyone? I'm willing to pay a reasonable price for an off cut as I know it's not cheap, but I really don't want to spend £30 - £40 on a bar, when I only need to make one bush.
Did you get this sorted?
I have a piece 70mm OD, 24mm ID and 37mm long.
Not quite big enough for what I need.
Still looking for an off cut, could be interested but I'll need to check the ID.
clubminiflip
Member #: 54
nr coventry
i'll check the metal supermarket by me rob i have to get some allysheet, i've seen what your after there just have to check the sizes, they're cheap there too usually, keep you posted bud!
I always get my metal off ebay. Lol
Probably pay a bit over the odds, but its convenient. They'll usually supply you with whatever size you want.
