Home > General Chat > More wide 10 inch tyres
Scruffy
Member #: 328
Seaford Rise, South Australia
Was loitering in our transport department the other day and we have a Brian James tri axle trailer for collecting Vipers in.
I looked at the wheels, looked again and they are fitted with some bad boy 195/55 R10s shame about the speed rating as they look well phat!
A bit better than the US golf cart tyres as they are UK available!
http://www.brianjames.co.uk/downloads/Moto...ttleNov07_2.pdf
Edited by Scruffy on 15th Jun, 2008.
On 5th Sep, 2011 Vegard said:
mokle
Member #: 2488
Edinburgh
I've seen a set of 225 55 10R but again speed rating was N which is about 80, still not bad if you are never taking it on a track.
Tony
Ive looked into using quad tyres, but theyre all N Rating like mokle says, 86mph tops. Does anyone actually know what happens when you exceed this speed?? Its a cataclismic failure or does the tyre just deflate??
mokle
Member #: 2488
Edinburgh
I imagine it would either rip apart or stretch itself off the rim.
I reckon they would be safe upto 100 with the safety tolerances, but wouldn't like to put that theory to the test *tongue*
tommyb
Member #: 934
halifax, west yorks
to get the speed rating for a tyre it has to be run for 10 mins at that speed, exceeding the speed rating will overheat the tyre and cause it to de-laminate = brown trousers or death!
they start to heat up and disintergrate when they go higher than the speed rating, my original mini tyres were only rated to somthing like 90mph, they started to bubble after awhile =/
