Home > Help Needed / General Tech Chat > valve stem seals
kav
Member #: 654
Just took my head off because I blew my HG, anyway was checking the valves out as my car allways smokes on start-up, and the place that fitted my new guides etc must have fitted the stem seals wrong because they're on the exhaust valves and not the inlets... anyway does anyone know the mg-rover part number for the head gasket kit that has the payen 450 gasket and the valve stem seals?
Cheers in advance,
Kav
j4m13_turbo
Member #: 2747
Peterborough
Hi mate,
If your looking for a full head set.. i will be able to get you one for 20 posted, This includes,
Head gasket
4 Valve stem oil seals
rocker cover gasket
Carb gasket
Exhaust gasket + inlet gasket
plus much more...
OR
If its only the valve stem oil seals i have 4 brand new spare onse *tongue*
PM me if interested
Cheers.
Nick
Member #: 154
Midlands
DK451 is the part code for the proper payen head gasket set.
Think i might just put it in my sig i post it that many times, lol.
kav
Member #: 654
Cheers guys, so to clarify the rover part number for the set containing the bk450 is dk451?
Cheers, Kav
kav
Member #: 654
It's just that I have an xpart dealer near me so they deal in mg-rover part numbers
Nick
Member #: 154
Midlands
dk451 is the payen part number, no idea if the rover one is the same, very doubtful though. I just order mine from a local motor factors or my local engine recon place.
Ric
Member #: 36
Basingstoke
i couldn't get a dk451 when i tried a few weeks ago. Had to get a bk450 and a cheapy headgasket set for the rest. Wasn't sure if the dk451 was still available...
kav
Member #: 654
yer i ordered the bk450 today from minispares earlier with the genuine gaskets and seals £20 but i've found genuine stuff often pays for itself over time
