| Home > Help Needed / General Tech Chat > clutch noise | |||||||
1st Aug, 2004 at 07:53:37pm
just run up my engine for the 1st time in ages... AlexF |
1st Aug, 2004 at 08:27:41pm
Take it you set the idle gear bearings ok?
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
1st Aug, 2004 at 09:03:02pm
alright alex, i have recently put my 1380 back together, and i have noticed an increase in noise in the clutch/drop gear area, i've put a few holes in the flywheel housing cover too
1st Aug, 2004 at 10:14:40pm
there is only noise when the engine is running in nutural... and it goes when you engage the clutch.
AlexF |
![]() 928 Posts Member #: 326 Post Whore bradford, west yorks |
1st Aug, 2004 at 10:42:44pm
just a quick guess, does it stop if you idle a litle faster, my orion diesel does this, it is the clutch thrust bearing i have been told...
1st Aug, 2004 at 10:45:25pm
well its a new thrust bearing that was slilky smooth after fitting.
AlexF |
3rd Aug, 2004 at 02:17:12am
glad im not the only one to notice the difference in pedal feel :) never goin back to verto :) turbo 16v k-series 11.9@118.9 :)
4th Aug, 2004 at 03:00:26pm
Have you changed the release bearing for the correct diagphram type?
4th Aug, 2004 at 03:02:04pm
Yup I did...
AlexF |
5th Aug, 2004 at 07:24:57pm
I have exactly the same probme!!! i have a large hole behind the starter motor letting out the noise. It goes if you rev it higher, and is loudest when idling low with the clutch out. if you solve it please let me know before i change the release bearing/ Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
