Home > Help Needed / General Tech Chat > carbon fibre
PEP
Member #: 1145
North Wales
Awright guy's?? Iv'e got a carbon fibre dasboard but would like to put 4 52mm holes into it. Would a holesaw do the job?? Is there a certain way of doing it/.?? thank you for you help.
Put Masking tape all over the place where you are cutting and go very steady, use a cordless drill that you vary the speed. Not one that just spins like a 240v one.
PS Measure and re-measure before you start
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
Best thing ive found on fibreglass and carbonfibre is my trusty dremel!
If I where doing that id mark where i want the gauge to go, drill a hole within that circle and use the girinding dremel to grind out to the line!
Might just be hassle doing it like that lol. But that way you can leave abit more meat on and see if the gauge would go in, then tickle bits off unitl it sits in noice and toit.
Edited by richminiturbo. on 18th Jun, 2008.
If ur unsure that the guage will sit in the hole the hole saw makes, test it out on some cardboard ect and see which saw looks best.
PEP
Member #: 1145
North Wales
cheers guys. Always appreciate your time and help.
no.1racer
Member #: 1163
Malvern, Worcestershire
A blunt tool will work better than a sharp one. Sharp blades often rip through the material. If you coul get hold of a blunt holesaw, i would ude one of those.
Its what i had to do on my carbon bootlid.
Sam
Member #: 1686
Oxford
wear it down on some scrap metal.
OMG Robert that's a big one
