Home > Technical Chat > Valve Spacing
Is the valve spacing (distance between the center of the valve guides) the same of all heads? specifically the 12G295 & the 12G940 or are the individual pairs of valves closer together & further away from the next on one head than they are on another. I hope that makes sense.
they're NOT the same on big bore and small bore.
Bollocks,
Does anyone know the spacing on a 12G295 or have one that they could measure? Mine's off being ported & I've only got 12G940 heads to hand.
Carl S
Member #: 1761
Stalker
I can measure mine tomorrow if you want? how accurate does the measurement need to be?
If you could measure that would be great, the more accurate the better really, as I'm trying to workout whether or not I need to offset bore my block and if so by how much.
Thanks
Rob
Carl S
Member #: 1761
Stalker
33mm Rob, centre to centre.
Cheers, Carl.
Edited by Carl S on 21st Jun, 2008.
