| Home > Help Needed / General Tech Chat > help fuel pump starts on position 2! | |||||||
3rd Aug, 2004 at 08:27:02pm
hello got my car running finally but on the ignition switch position 2 the pump comes on and according to the era text etc it shoul come on on pos 3. any help would be great i have checked the relay wiring and it seems perfect : ( |
126 Posts Member #: 244 Advanced Member |
3rd Aug, 2004 at 11:28:43pm
position 2?
Speedster turbo under construction |
4th Aug, 2004 at 12:47:03am
no i have to turn the key 2 clicks and it comes on then 1 more to fire itt up before it returns to pos 2, cheers for the advice about the switch will try it |
4th Aug, 2004 at 01:09:42am
thats the same as mine dude. its a switched live, the stereo comes on after the first click in the accessory position. i'd have thought thats how everyones works as pos 3 is only used to start the car. On 20th Oct, 2015 Tom Fenton said:
4th Aug, 2004 at 01:33:16am
i did think that but all the write up for the diagrams suggests otherwise have other people run it like mine? |
4th Aug, 2004 at 03:58:28am
it should technically come on on position 3 or when the oil pressure is high. see your other post. turbo 16v k-series 11.9@118.9 :)
166 Posts Member #: 221 Advanced Member |
4th Aug, 2004 at 02:13:48pm
Mines works off position 2. Never had any problems.
4th Aug, 2004 at 07:17:25pm
tried the switch no luck any ideas? |
4th Aug, 2004 at 08:43:38pm
see other post Speedster turbo under construction |
538 Posts Member #: 119 Post Whore Staffordshire or Northamptonshire |
5th Aug, 2004 at 11:08:36am
The era was wired through thru an oil pressure switch, so that in the event of an accident and the engine stopping, the oil pressure drop would cause the switch to open and stop the pump. Only problem is how do you get fuel to your engine before it fires into life (maybe not enough oil pressure from cranking on starter & slow). So a link from the starter solenoid was run to the fuel pump. When ignition at 3 the current flowed to the pump from the solenoid untill oil pressure was sufficient to operate the oil switch.
5th Aug, 2004 at 08:58:15pm
i run both era system with an inertial switch but bear in mind what other people have recommended that the inertia switch should be wired to your ignition to to avoild excessive lean out should you hit a pothole etc and your pump might cut out no longer a series, but still 1.3 turbo.
6th Aug, 2004 at 01:24:34am
what do you mean by lean out, i think i have the wiring sorted now much simpler than the era diagram. i will post a diagram once i do a few more checks and if anybody wants it! cheers for your help |
