Home > Help Needed / General Tech Chat > 1320 turbo
dave1700t
Member #: 347
hi all,
im new to these boards, will post an intro in due course
i have a mark 3, im rebuilding, currently have a decent 1320 engine in the car running (or should be when i finish the car) running on a weber 45.
but im used to 3 litre cars, and dont think that is going to be enough power for me, so ive been looking into the vauxhall engine conversions. but to be honest, i really cant be bothered with taking all the subframe out again, and cutting the front off to extend it, as its deseamed.
anyway, finally getting to the point, would i be able to run a turbo setup on this engine? or does it really need to come out to make way for a turbo engine?
many thanks
dave
minimark
Member #: 19
newcastle
C/R bound to be your major problem.
yep thats the problem as mark says. depends what it is at the moment though, you may get away with a big chambered head.
Its the first thing to consider. Plus how strong the pistons are.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
1320?
what bore is that?
alex
AlexF
dave1700t
Member #: 347
am not sure on the exact spec of the engine. brought it from a guy whose car got stuffed from behind by a volvo. if c/r is a problem, how could this be lowered?
clubman_dan
Member #: 142
Winchester
big chambers in the head, deep dish pistons, dunno if theres any other ways.
DAN :)
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
haed mods... or new pistons!
alex
AlexF
dave1700t
Member #: 347
so in theory then, al i need to do is change to a decent turbo head, or do some work on the existing head, and it should run ok with the turbo setup. is this right?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
yup *happy*
alex
AlexF
minimark
Member #: 19
newcastle
If you have flat top pistons , you`re in the shit cos your gonna need a 40cc head !!!!
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
or very low boost!
alex
AlexF
