Home > Help Needed / General Tech Chat > clutch problems
Tweaked
Member #: 2873
Hi guys got a clutch problem, i've looked over past posts but nothing common with my prob.
I got a copper racing clutch in, my system is bleed properly and i got the extenstion arm for the slave, slave cylinder and master have both been overhauled, the slave does push the arm back but i still can't engage any gears even wen the arm is fully adjusted.
A little help will be really appreciated.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
What does a copper clutch look like? Never seen one....have you got pics?
On 19th Jan, 2010 wil_h said:
Tweaked
Member #: 2873
sorry man i don't, it was ordered and put in for me
pinkyandnobrain
Member #: 2588
Pretoria South Africa
Check that the clutch arm hasnt bent or broken off at the bottom where it goes into the thrush bearing plunger. If it is bent get a new 1 as second hand 1s dont last .
Dan
"Try to take over the world!"
