| Home > Wanted > Wanted standard turbo piston/pistons | |||||||
319 Posts Member #: 1742 Senior Member essex |
24th Jun, 2008 at 07:50:04pm
Hiya im after either 1 good second hand turbo piston with rings 20832 L8 with stamp B or if somone has a full set of turbo ones on standard bore also with rings. Thanks j My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901 |
24th Jun, 2008 at 09:35:24pm
I think you will struggle to find a good set, a re bore is not that expensive...
24th Jun, 2008 at 10:10:18pm
Hiya the rebore isnt that bad but which pistons to go for? i just wanted to get it together as quick as to get it all working. Its for a supercharged engine so the pistons wont be working as hard but i still dont know what to go for do i save and buy a forged set £400+ of do i get a cast set for £180-£280 i know some use the cast with high boost and no problems. My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901 |
24th Jun, 2008 at 11:33:13pm
cast OMEGAS around £270 from MED engineering.
25th Jun, 2008 at 06:01:49pm
cheers guys if i have to i will get a set but will have to wait a bit longer. I just wodered if someone had a good piston to make my ones a set it would get me by. My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901 |
25th Jun, 2008 at 09:49:47pm
Minispares mega pistons are also very good, same casting as the turbo piston and uses an omega ring pack.
