| Home > Help Needed / General Tech Chat > Dump valve for supercharger | |||||||
39 Posts Member #: 2402 Member |
25th Jun, 2008 at 12:22:48pm
I now that a simple dumb valve don't worck very well on a blow setup supercharger, but if I put 2 dump valve:) whit a t piece on the manifold job? what we think? |
25th Jun, 2008 at 12:31:30pm
A dumb valve on a supercharger doesn't sound very clever.
In the 13's at last!.. Just |
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
25th Jun, 2008 at 12:33:34pm
Gaincooper,
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
25th Jun, 2008 at 01:44:49pm
is it going on a suck through or blow through set up. If suck through then surely when the valve is open it will be blowing unburnt fuel out... |
319 Posts Member #: 1742 Senior Member essex |
25th Jun, 2008 at 06:52:51pm
with a blow through setup which i think is the way you were going the back pressure still builds up putting extra strain on the supercharger and belt also it will push past the carb and self rev (i know someone who tried). double or multiple dump valves may work or get yourself the valve from the bmw mini it is a vacume opperated buterfly valve which will dump the boost when your oot comes off. On the bini it is plumbed back into the supercharger inlet but you might not want to. The amount of air produced on run down is pretty amazing. My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901 |
26th Jun, 2008 at 01:14:51am
On 25th Jun, 2008 Ric said:
is it going on a suck through or blow through set up. If suck through then surely when the valve is open it will be blowing unburnt fuel out... Correct. On a supercharger setup, it is ESSENTIAL that when you close the throttle, any air still being pumped, is either re-circulated, or dumped. Failure to do so, could result in damage to the blower over time. A blower doesnt suddenly stop pumping air when you close the throttle at 7000rpm like a turbo can. That air has to go somewhere. On a suck through, it doesnt matter because when you close the throttle....the blower doesnt have any air to pump. If the throttle is between the blower and engine, then some form of dump or bypass is a must. 9.85 @ 145mph
