Home > General Chat > Putting the Dizzy Back In
Someone mentioned this in another thread no long ago but i cant find it for the life of me. When putting the dizzy and drive back i need no1 at TDC where does the big notch need to pointing??
Mike
Mike
can't remember, but if you put the dizzy drive on the end and put the rotor arm sin the right place at TDC, you can see for yourself which way it goes.
carl
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
Pretty sure it was 3 o'clock position
The rotor arm should be pointing to cylinder no.1 assuming no.1 cylinder is at TDC and the valves are on the rock.
I prefer 1 o'clock but its up to you really as long as you get the timing correct
Paul
