Protect your pride and joy!
The alarm was professionally fitted and when I sold the car it was removed properly. (I use to install these alarms).
I have bench tested the alarm as it has been just been in storage for a while, everything works ok. Everything will be supplied: LED, siren, brain, 2 x remotes, microwave interior sensor etc.
The loom is obviously used but it is not butchered, and because the alarm was fitted to a 'average' sized car the loom could be un-tapped and easily made to fit a mini. I will clearly identify the wires and assist (online) in anyway I can to help you fit it - I would advise you have some understanding of car electricals if you are going to attempt fitment yourself. (I suspect I can provide the original engineers wiring guide as well )
The alarm itself can be programmed via a PC to adjust siren tones and trigger events (need an additional cable - not supplied).
Any questions just ask.
The owners manual can be found here:
http://www.directeddealers.com/manuals/og/...00uk_owners.pdf
I have watched a couple of this units sell on ebay recently for £50+ so I am asking £40 + P&P.
(I have a 2nd identical alarm but have not had a chance to test it yet and can only fit one remote at the moment!)
