| Home > Help Needed / General Tech Chat > thanx feeble uk | |||||||
100 Posts Member #: 344 The Royal Mail lose every parcel I ever send.....and I am a TWAT |
4th Aug, 2004 at 11:19:01pm
feeble came to have a look at my metro today why it was starting running then cutting out he found out why.My fuel pump wasnt switching on on poss 2 but only when i was turning it over thus using that fuel then cutting out he changed a wire round i had on my oil pressure sensor and it worked must have somthing to do with that .But my engine still smokes really bad only when its cold just had it fully recond not even done 1 mile all cylinders have good comp 170 on each but i did wash the bores with petrol by mistake do you think this may have damaged an oil ring or maybe it could be a valve stem or seal its only doing it on cylinder 4 tho any ideas mutch apreiciated cheers lee |
5th Aug, 2004 at 12:59:00am
o/t but why is it always cylinder s 3 or 4 that go 1st on a-series engiens in my experience??
5th Aug, 2004 at 10:33:43am
If it is a new engine that has had the bores honed and new piston rings then it probably will smoke a bit when cold until the rings have bedded into the honed surface of the bore.
5th Aug, 2004 at 04:21:00pm
thoughjt that but it fills my garage with smoke aaaaaaaaahhhhhhhhhhh cant breath |
126 Posts Member #: 244 Advanced Member |
5th Aug, 2004 at 06:36:37pm
you shouldn't run your engine in the garage anyway! Carbon monoxide poisoning is worse than 40 a day (cigs that is)
Speedster turbo under construction |
5th Aug, 2004 at 07:20:00pm
it was just a wiring problem, hes put a carb and manifold on to get it running and it still smokes, so it wasnt the turbo for definate Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
