Home > Help Needed / General Tech Chat > problem with my engine
fuiafonte
Member #: 695
PORTUGAL-VISEU
hello, I have a problem with my engine.i can´t overcome the 3000 rpm in the road.if i have the car steady in the same place"stoped" the car goes up in the rotation well ,but in progress does not exceed the 3000 rpm.i have everything should be as pump bosh, the appropriate pressure so what can be?
Edited by fuiafonte on 3rd Jul, 2008.
Have you had the car running properly before this?
Truly amazing, the english explains the problem perfectly, but it's not how I would ever write it. Better than some would write it who have english as a first language.
Anyway, I suspect that your problem is that you have the plenum to carb gasket on the wrong way round, or you have the wrong gasket. Either way, I would guess that the hole to allow the float chamber to be pressurised is blocked.
this thread might help http://www.turbominis.co.uk/forums/index.php?p=vt&tid=6298
Edited by wil_h on 1st Jul, 2008.
ha, agreed, so its only when the car is under load
has it always been this way? or has this only ocurred recently?
im pretty sure wil has hit the nail on the head
Turbo Tel
Member #: 588
Delaware, USA
LOL...
I work for a German company and sometimes go there to write technical documents. My German collegues sometimes bring descriptions to me to be "checked" Often (but not always!) they are perfectly correct and understandable yet getting the text to explain the subject just as well but with correct sounding English can be a bear!!
I always keep in my head that their English is a shit load better than my German!!
I also vote for the Carb/Plenum gasket..
Edited by Turbo Tel on 1st Jul, 2008.
fuiafonte
Member #: 695
PORTUGAL-VISEU
i have already read the topic and i have just understand what is the trouble.thank you
fuiafonte
Member #: 695
PORTUGAL-VISEU
no.. ´
please read this wrote by TurboDave
this explains it all ................!! http://www.turbominis.co.uk/forums/index.php?p=vt&tid=2103
Kean
Member #: 341
aka T2clubby
South Staffs
Yeah sounds like an open connection on the carb somewhere to me. Good english!
