| Home > Help Needed / General Tech Chat > Give Me More Head - solid exhaut valves V;s sodium filled valves | |||||||
![]() 826 Posts Member #: 247 Post Whore Kent/Surrey Borders |
5th Aug, 2004 at 01:12:31pm
Chaps .. TurboLessTosser |
5th Aug, 2004 at 01:33:21pm
My understanding of the sodium exhaust valves is that they are used as they conduct heat away from the valve head more quickly, thus attempting to avoid burning the valve seat away.
5th Aug, 2004 at 01:37:56pm
I still have the sodium valves in my head.
5th Aug, 2004 at 01:39:13pm
Tom is right its all about heat transfer...
AlexF |
5th Aug, 2004 at 04:25:37pm
I thought that most valves were made fron 2 pieces.
5th Aug, 2004 at 04:31:31pm
most valves are... but head drop is normaly poor quality or more likly over heating.
AlexF |
5th Aug, 2004 at 08:38:46pm
Well I always thought that all valves were two-piece aswell, but Jim told me that MorSpeed have just fitted some new one-piece valves to his head... On 17th Nov, 2014 Tom Fenton said:
6th Aug, 2004 at 09:10:06am
nah you can make them out of a single lump of metal...
AlexF |
6th Aug, 2004 at 09:22:50am
Tell us more then!
6th Aug, 2004 at 09:38:42am
I'll have to do some digging... not sure on mini specific valves.
AlexF |
7th Aug, 2004 at 12:27:21am
No Dave rim flow valves are 2 piece!
146 Posts Member #: 350 Turboing minis since '89 Supercharging minis since '04 |
10th Aug, 2004 at 05:10:28pm
ive heard but not seen the turbo valves' heads coming off ,somtimes it can be put down to using old valves with vague history ,work hardening , fatigue etc, use new rover - some replacement parts are solid valves -,i use solid stainless two piece - the two parts are the valve main shape and a harder metal'stellite' section friction welded to the top where the rocker touches - not the head and stem being joined as most people think ( and chrome stem - 3rd part !!?) most valves are made this way , either stamped from stainless rod (about 10mm dia ) like a nail ,or a form of casting /forging as most standard type valves and both methods require turning or grinding to shape to finnish |
12th Aug, 2004 at 01:14:10pm
I always thought that the Minispares £10 "race" valves were one-piece. I've used these in high rpm engines and had no problems. No racing though. Then again, the standard Rover valve's stems never seem to wear. They must be good, although two-piece. On 13th Jul, 2012 Ben H said:
63 Posts Member #: 325 Advanced Member |
12th Aug, 2004 at 02:18:18pm
Wouldn't a water injection system help keep the valves cool? |
12th Aug, 2004 at 03:08:31pm
think that the water injection is tricky for similar reasons to injection.
12th Aug, 2004 at 03:26:22pm
Water injection supresses det more than cools valves.
AlexF |
13th Aug, 2004 at 06:56:18pm
it suppreses det by cooling the mixture though ?
15th Aug, 2004 at 07:25:52pm
It supresses det by slowing flame speed and hence pressure rise...
AlexF |
![]() 151 Posts Member #: 165 Advanced Member Cambridge |
16th Aug, 2004 at 07:27:35pm
A small thing i will say is sodium filled valves weight more thus sapping a little bit of power compared to the solid valves. Not much tho so don't bite my head off. |
