Home > MS Trials & Testing >
Yes, the voltage at Vcc (measured with the same DVM) compared to the voltage at the Hall switch will be interesting. It will prove the effectiveness of the way the MS-Extra diagram that you are using, is at using the 5V supply to pull-up the output of a 12V device.
I can't get my head around it properly at the moment but it doesn't seem "right".
And if you have any resistance at your soldered joints.... Well, shame on you !!!
