| Home > Help Needed / General Tech Chat > Fuel pressure creep? | |||||||
1st Jul, 2008 at 11:38:39pm
Bit of an odd one!
1st Jul, 2008 at 11:41:52pm
could the pump not be giving constant pressure? "Turbo's make torque, and torque makes fun"
1st Jul, 2008 at 11:45:43pm
Hmmm good point, any suggestions of how I could check though? Ive already got a pressure gauge in between the pump and inlet to FPR.
2nd Jul, 2008 at 12:37:38am
Having had the regulator plumbed in backwards originaly and pressures of 90psi, maybe the regulator cap is damaged? On 26th Oct, 2004 TurboDave16v said:
2nd Jul, 2008 at 12:41:32am
On 1st Jul, 2008 matty said:
Ive already got a pressure gauge in between the pump and inlet to FPR. So tthat should be the rail pressure Tank, pump, fuel rail, guage, regulator, tank? Also, are you using the correct grade fuel lines. fuel systems that return fuel to the tank continuously oxygenate the fuel and requires a special grade of hose. On 26th Oct, 2004 TurboDave16v said:
2nd Jul, 2008 at 12:43:24am
On 1st Jul, 2008 joeybaby83 said:
could the pump not be giving constant pressure? The regulator controls the fuel pressure, not the pump. On 26th Oct, 2004 TurboDave16v said:
2nd Jul, 2008 at 03:20:30am
I'm confused.. probably because I know Nowt about Fuel Injection
Edited by Turbo Tel on 2nd Jul, 2008. website:- http://www.terryhunt.co.uk
2nd Jul, 2008 at 08:18:35am
I thought Joe's point could be valid if for some reason the pump isn't staying a constant speed and the return hose is no longer sufficient to return the excesss fuel? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
2nd Jul, 2008 at 08:45:46am
Could it be a sensor problem?
2nd Jul, 2008 at 08:48:26am
On 2nd Jul, 2008 Sprocket said:
Also, are you using the correct grade fuel lines. fuel systems that return fuel to the tank continuously oxygenate the fuel and requires a special grade of hose. On 28th Aug, 2011 Kean said:
2nd Jul, 2008 at 10:58:35am
could the seal on the fpr be leaking slowly ,and letting fuel above the piston.. that gradually builds up pressure on top of the piston and creatres a rise in the fpr setting . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
2nd Jul, 2008 at 12:03:52pm
sounds pretty feasable robert, possibly due to connecting the wrong way?
2nd Jul, 2008 at 12:17:57pm
You should be referencing boost at the top of the piston, so pressure should not creep due to leakage.
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
2nd Jul, 2008 at 12:31:30pm
is this a standard metro rising rate fpr? If so, is your new fuel pump too strong for it?
2nd Jul, 2008 at 12:47:25pm
On 2nd Jul, 2008 Ric said:
is this a standard metro rising rate fpr? If so, is your new fuel pump too strong for it? I'm sure i read something on here a few years ago posted by either wil or ben about putting a bmw pump on their car and it trashing the diaphragm in the fpr. Might be worth a look. Not us, we had low flow problems. But yes, streached diaphrams is a known problem with very high pressure pumps. Keep below around 65psi to be safe I think. Even the most powerful high boost motors on here shouldn't need more than 45psi, most need less than 30. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
2nd Jul, 2008 at 12:50:58pm
Matty is on fuel injection on his K1100 Turbo in this instance.
2nd Jul, 2008 at 01:08:44pm
On 2nd Jul, 2008 Paul S said:
Matty is on fuel injection on his K1100 Turbo in this instance. He is going to need 4-5 bar. 65 psi was a guess based on what I have run and the diaphram has survived. Say he needs 5 bar (73.5psi) then I reckon he'll still be ok, if using the metro FPR. What I don't fully understand is why the fuel pressure is increased with boost on an injection engine. As the pressure of the fuel exiting the injectors is way above an boost levels that will be run anyway. So shouldn't just increasing the injection window be enough? Or is there an issue with suitable injector sizes; small enough for tickover and big enough for full power. Changing the pressure will effectively give the injector a wider spread of flow adjustment. don't know. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
2nd Jul, 2008 at 01:32:10pm
The best method is to maintain a fixed differential pressure across the injector, so fuel pressure goes up with boost.
Edited by Paul S on 2nd Jul, 2008. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
2nd Jul, 2008 at 04:28:03pm
Ive taken the FPR apart and think I may of found the problem! Will confirm later! https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
2nd Jul, 2008 at 06:53:49pm
Well looks like all is well! https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
2nd Jul, 2008 at 07:16:41pm
i rekon your problem is a peice of string/fiber in the FPR try taking it apart and cleaning it out then going for a 45 min drive. should sort it out i rekon!
Edited by James_H on 2nd Jul, 2008. |
2nd Jul, 2008 at 07:43:44pm
Paul is right about fuel pressure. The DON works like this, fuel pressure falls with vacuum and rises with boost to maintain a constant differential pressure.
2nd Jul, 2008 at 07:47:09pm
was the fibry shizzle on the fuel or air side of the FPR?
2nd Jul, 2008 at 07:51:25pm
That's something else I've learned about injecting a turbo. It'll all come in handy when I dig the K100 head out of the shed. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
2nd Jul, 2008 at 08:01:54pm
On 2nd Jul, 2008 mini13 said:
was the fibry shizzle on the fuel or air side of the FPR? i ask cause when i pulled the sender unit out of my tank it was covered in what looked like fireglass/wool. It was in the fuel side, so could well be that I suppose.
so thats working ok
honest i really am that clever.....
