| Home > Technical Chat > 998 rods | |||||||
1st Jul, 2008 at 11:40:40pm
Right lads I was doing a little thinking (always dangerous) is there any reason [bar the gudgeon Pin Diameter ] why it would not be possible to use a 998 rod in a 1275 casting or has this been done
On 17th Feb, 2009 Rob H said:
2nd Jul, 2008 at 12:49:33am
Offsets on the 998 rods are all wrong for a 1275 On 26th Oct, 2004 TurboDave16v said:
2nd Jul, 2008 at 08:05:11am
Also, Cooper S rods are EASY to get hold of. Just have a look on Ebay. Prepare to pay between 100 and 150 for a serviceable set.
2nd Jul, 2008 at 11:07:28am
Off set I will look into that, Im not convinced there all that week I probly should have said I want these rods to work in a 10 hour motor to do a job,
2nd Jul, 2008 at 11:43:48am
On 2nd Jul, 2008 PaulH said:
Off set I will look into that, Im not convinced there all that week I probly should have said I want these rods to work in a 10 hour motor to do a job, A week or ten days? On 13th Jul, 2012 Ben H said:
2nd Jul, 2008 at 11:52:26am
2nd Jul, 2008 at 12:54:27pm
offset mightg be able to be adjusted for if your thinning them? "Turbo's make torque, and torque makes fun"
2nd Jul, 2008 at 02:02:11pm
Ok after a little bit more study today I have come up with the following,
2nd Jul, 2008 at 11:46:07pm
Dont forget that a 1275 piston, pin and rings weigh more that a 998 piston, and you want to reduce the metal on the little end. Maybe they will maybe they wont bee up to the job. Austin Rover did ttend to over engineer everything about the A series.
2nd Jul, 2008 at 11:54:57pm
Very good Point there Sprocket,
3rd Jul, 2008 at 01:06:19am
could always use the S sized sprite/midget rods as a cheaper alternative. less than half the price of S rods usually. On 20th Oct, 2015 Tom Fenton said:
3rd Jul, 2008 at 09:06:54am
Why don't you contact Steven Gault in your country. He'll do them! On 13th Jul, 2012 Ben H said:
3rd Jul, 2008 at 05:41:45pm
Gault is a Nordy but close enough On 7th Nov, 2008 Nic said:
5th Jul, 2008 at 09:56:54pm
Ha Lads I was just poking around a friends garrage last night an came across a set of 1275 rods with the casting number AEG 625 MF A1 are these Midget/sprite or cooper S more to the point are they of the 1.62 variety I could not measure them there and then because I was supost to be at a christening not snooping trough his garrage :)
6th Jul, 2008 at 04:18:26pm
Midget ones, small journal.
6th Jul, 2008 at 06:24:01pm
Thank you kind sir Ill take the easy option so and grab these the week end he will be delighted with his new set of big bore 1275 rods :)
