| Home > How To > | |||||||
444 Posts Member #: 2885 Senior Member |
3rd Jul, 2008 at 07:40:08pm
hmm.. if we use a restrictor ring in the plenum to create a slight delay in pressure felt by the venturi allowing the pressure pipe going to the float bowl to keep the float several psi above boost pressureslightly richening the mixture as the boost rises then the correct A/F ratio can be caken care of by the carburettor. This ovcourse stops the fuel and boost pressure becoming even at which point nothing would come out the needle..
