| Home > Help Needed / General Tech Chat > A plus dizzy in a series block | |||||||
![]() 465 Posts Member #: 1972 Senior Member Worcester |
5th Jul, 2008 at 04:26:30pm
Hi guys, i remember seeing somewhere a converter to run an A plus distributor in a pre A plus block i think, or is it the other way round? Cant seem to find anything anywhere on it or am i dreaming lol? Any help appreiciated,
5th Jul, 2008 at 05:46:44pm
you can mod a dizzies to fit a+, but im not sure about vica versa "Turbo's make torque, and torque makes fun"
5th Jul, 2008 at 06:08:20pm
seem to remember that Jukka Harkola did this once....maybe worth a look on his homepage |
348 Posts Member #: 2253 Senior Member Las Vegas, Brit in the States |
5th Jul, 2008 at 08:09:22pm
6th Jul, 2008 at 08:31:28am
Its not difficult, you just need to change the drive dog(redrill for the rollpin at 90 degrees) and mill out the A series clamp to 40mm to hold the A+ dizzy.I also drilled the end of the shaft and tapped it to take a small extension to locate it at the lower end, as the A+ shaft is shorter.Quite important, even though it will run(for a while) without it. |
6th Jul, 2008 at 10:12:27am
I should also have mentioned that this rotation of 90 degrees might mean that the vacuum advance can may foul if you have a T piece adaptor for oilpressure guage and /or the turbo oil feed.My solution was to tap the top of the big banjo bolt holding the main external oil feed pipe 1/8 NPT and put everything on to that. |
6th Jul, 2008 at 11:45:20am
that will supply you with unfiltered oil instead of filtered though.... |
6th Jul, 2008 at 03:46:24pm
Ok cheers il have to get my dizzys out and have a look |
