| Home > Help Needed / General Tech Chat > Ummm bit stuck here part 2 | |||||||
141 Posts Member #: 2408 Advanced Member surrey / ewell area. |
7th Jul, 2008 at 03:38:42pm
Right just a thought if i took a plug out and tested its spark against the block how strong should said spark be ? like an electric lighter spark or like a spot weld spark because if its the latter then that would explain why the engine is not running when the pump turns on . because my spark is more like the first mentioned. just starting to think it could be the ign system somehow. |
