| Home > Wanted > turbo bits | |||||||
8 Posts Member #: 3027 Junior Member melbourne australia |
8th Jul, 2008 at 09:45:59am
I am after a manifold to go between a 45 webber and a garrett gt 17 turbo if you can help that would be good 450kg 125 hp at rear wheels heaps of fun waiting to happen |
8th Jul, 2008 at 10:18:27am
I assume you want an exhaust manifold to fit a GT17 allowing space for a webber inlet.
Edited by wil_h on 8th Jul, 2008. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
8th Jul, 2008 at 11:08:29am
And a custom made plenum chamber.
In the 13's at last!.. Just |
8th Jul, 2008 at 11:44:34am
intake chameber not a problem
8th Jul, 2008 at 12:14:28pm
Am a bit confused, what do you actually need then? Edited by t3gav on 8th Jul, 2008. |
8th Jul, 2008 at 12:18:02pm
On 8th Jul, 2008 gavin@minispares.com said:
Am a bit confused, what do you actually need then? me too? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
8th Jul, 2008 at 12:22:14pm
? "Turbo's make torque, and torque makes fun"
8th Jul, 2008 at 12:29:45pm
WE HAVE THE MANIFLOD FROM THE TURBO TO HEAD
8th Jul, 2008 at 12:32:09pm
OK!!! On 8th Jul, 2008 justfanginaround said:
WE HAVE THE MANIFLOD FROM THE TURBO TO HEAD WE HAVE THE PLATE TO JOIN THE GT17 THE EXHAUST MANIFOLD WE DO NOT HAVE THE MANIFOLD TO JOIN THE WEBBER TO THE GT17 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
8th Jul, 2008 at 12:32:10pm
we are using a draw through the carb set up 450kg 125 hp at rear wheels heaps of fun waiting to happen |
8th Jul, 2008 at 12:33:01pm
you mean a tube?
Edited by joeybaby83 on 8th Jul, 2008. "Turbo's make torque, and torque makes fun"
8th Jul, 2008 at 12:36:00pm
tube isn't that what you guys call a beer can ????
8th Jul, 2008 at 12:37:49pm
Ahhh.
8th Jul, 2008 at 12:39:39pm
It is going onto an A+ engine that has 125 rear wheel hp { mid mount motor in a NOTA FANG } we are aiming to run 6 psi, 10/1 comp. max revs 8g
8th Jul, 2008 at 12:41:15pm
we allready have fitted a carbon seal to it so it will be able to be used in a draw through set up 450kg 125 hp at rear wheels heaps of fun waiting to happen |
8th Jul, 2008 at 12:51:56pm
hey bud, why dont you introduce yourself in the other section, with a bit of info about what your intending to do, would make it a hell of a lot easier to help "Turbo's make torque, and torque makes fun"
8th Jul, 2008 at 12:52:17pm
Excellent. You seem to have it all in hand.
