| Home > Wanted > lightweight steel flywheel | |||||||
![]() 368 Posts Member #: 806 Senior Member Cirencester, Gloucestershire |
10th Jul, 2008 at 10:26:51pm
i'm after a ultralight or similar steel flywheel, pre-verto and for old-type (inertia?) starter. i can swap my current flywheel, which is the same spec but with pre-engaged ring gear, or can pay with actual money
11th Jul, 2008 at 01:17:17am
if no one come up Tom
Edited by BENROSS on 11th Jul, 2008.
11th Jul, 2008 at 07:55:39am
I've got a couple of backplates if wanted?
11th Jul, 2008 at 07:42:43pm
Can't you change the ring gear? On 5th Sep, 2011 Vegard said:
